o2 sensor located on cat
Old Oct 31, 2002 | 04:17 PM
LillDragun's Avatar
Default o2 sensor located on cat
how do i take this off and put a new one on? mine is messed up. do i have to take the whole cat off?? please explain this to me. thanx
Old Oct 31, 2002 | 04:32 PM
GSRaCeRbOI's Avatar
Default Re: o2 sensor located on cat (LillDragun)
there are some sockets that are split/have a split for the wiring.. they are called "02 sensor sockets" ... I haven't personally undid the 02 from the cat.. but this is what I heard people use... maybe you can also use an open end wrench... dunnoz..
I'll try to get a pic.. hold up..
EDIT: this isn't my pic... i just found it on the net.. and its not for a teg but it shocks the socket..
http://www.pbase.com/image/2965417
[Modified by GSRaCeRbOI, 5:41 PM 10/31/2002]
Old Oct 31, 2002 | 04:46 PM
EL Vap133's Avatar
when I installed my header, I used a open wrench to take off the 02 sensor and put it on the header on my 97 LS, it should be the same on yours...
Old Oct 31, 2002 | 04:47 PM
Etylorcen's Avatar
Default Re: o2 sensor located on cat (GSRaCeRbOI)
You can just remove the cat first, it'll be much easier this way, or you can just get a monkey wrench and get it off. When putting it back on though dont forget to pretwist the o2 sensor so when you screw it on it will be straight.
Old Oct 31, 2002 | 04:48 PM
Dan GSR's Avatar
Default Re: o2 sensor located on cat (Vap133)
go to sears ask for a flare nut wrench
Old Oct 31, 2002 | 04:59 PM
B2FiNiTY's Avatar
Open ended wrench. 22mm.
Old Oct 31, 2002 | 05:21 PM
LsVtecDA's Avatar
Default Re: o2 sensor located on cat (B2FiNiTY)
I took mine out when I put my header on two nights ago. You should be able to unscrew it with out taking the cat off, but its gonna be tight. Spray something on it to losen it up.
tronic
Mar 14, 2011 06:45 AM
JDM-Vic
Apr 29, 2010 05:04 PM
iam7head
Sep 27, 2002 07:00 PM
TypeRRRR
Aug 5, 2002 04:40 AM
intekragsr
Feb 4, 2002 06:35 AM
