** Prep specifically for Certi-fit bumper covers?
Old Aug 17, 2014 | 10:49 AM
jfoster's Avatar
Default ** Prep specifically for Certi-fit bumper covers?
So I have a certifit front cover for my integra. I've read 100 different things on the web but a lot of different methods suggested for different manufacturers.
I'm sure there are people on here that have shot certifit covers with success.
Did you do something other than soapy wash, red scotch Brite (or grey?), and wax & grease remover?
I have primer, base, and clear ...did you start with an adhesion promoter like bulldog?
I already did the oem rear with Duplicolor champ white, it was easy to use and relatively cheap. But it's not champ white, its a bright white more like frost white.
So I went to my local Whole Sale Auto Paints and got an actual champ white mix, with all the primer clear and reducer activator etc. I'm $115 into paint for the front and don't really want to put $100's of paint on a certifit cover. Guy there said most people don't use the bulldog due to the extra expense.
Old Aug 17, 2014 | 11:02 AM
Hawkze_2.3's Avatar
Default Re: ** Prep specifically for Certi-fit bumper covers?
I like to use the red Scotch Brite with soapy water, then W&G remover before adhesion promoter.
What kind of primer do you have?
Adhesion promoter is important. Figure out what type of plastic it is made of and use either SEM '38363 SAND FREE' for ABS, PVC, etc; or use SEM '39863 PLASTIC ADHESION PROMOTER' for PP, TPO, etc. Check the SEM technical data sheets for more info.
I've done several Certi-fit bumper covers that have not had any issues even with lots of highway miles.
Old Aug 17, 2014 | 12:00 PM
Hawkze_2.3's Avatar
Example:
Old Aug 17, 2014 | 03:46 PM
jfoster's Avatar
Damn that's a good looking Prelude.
Anyway, found a sticker inside the bumper and it says it's already primered....here's what I'm working with.
Old Aug 17, 2014 | 08:41 PM
Hawkze_2.3's Avatar
Thanks, looks like you have some decent products.
I would sand/scuff the bumper and use the SEM stuff before priming (just in case), then when your primer dries dust a guide coat on it. Then wet-sand the cured primer w/guide coat and you should be ready for paint.
Old Sep 17, 2014 | 12:53 PM
B and B's Avatar
Loved
Community Favorite
how would he determine what kind of plastic it is? Is it stamped with a code like a plastic bottle?
Old Sep 17, 2014 | 05:15 PM
PanchoEK's Avatar
It seems like everybody is doing too much work and using too many products, most all reman. bumpers are already primered so I just use a gray scotch brite, blow it off and tack it, sealer, base, clear. Never had any issues with paint adhering or issues after
Old Sep 19, 2014 | 05:09 AM
Hawkze_2.3's Avatar
Yep, all plastic car parts that I have ever seen have the plastic type molded in.
Old Sep 19, 2014 | 05:11 AM
Hawkze_2.3's Avatar
OK....so you are saying prep > clean > sealer > base > clear. How is that any different from what everyone else is saying?
Old Sep 19, 2014 | 03:05 PM
PanchoEK's Avatar
It's different because I'm telling him how to get it done, and people are putting to use grease and wax remove it, apply adhesion promoter, primer it etc. Why primer it when it's a new bumper and already comes primered, I'm just making things more simple
Old Sep 19, 2014 | 07:15 PM
Hawkze_2.3's Avatar
If it was my car I would rather have the primer done the right way rather than whatever low-budget method Certifit uses...but that's just a personal preference.
Old Sep 30, 2014 | 09:10 PM
Hidenplanvew's Avatar
If your spraying w/o wax and grease remover, your just plain doing it wrong
Old Oct 7, 2014 | 12:12 PM
92cxyd's Avatar
I've bought a lot of Cert-Fit bumpers for Civic and they never come primed.
The metal fender and hoods are primed.
Old Oct 7, 2014 | 07:55 PM
I have got Sorta fit many times so are sealed and some not... all it is a epoxy type paint.
Old Oct 26, 2014 | 05:58 AM
VKSninja's Avatar
The step should be. Wax and grease. Sand. Wax and grease. Adhesives. Prime. Wax and grease. Sand. Wax and grease. Base coat. Tac rag in each coat. Clear. Done.
Old Nov 23, 2014 | 06:44 PM
spoolinfool's Avatar
Do what PanchoEk said and keep it simple, the more layers and steps you introduce will end up complicating a simple job.Just scuff really well and make sure you don't sand or scuff through the factory primer.
Old Nov 25, 2014 | 04:43 PM
ekay. jay's Avatar
If the bumper already has primer on it there is absolutely no point in putting more primer on top of it. I would scuff the bumper wet with a scotch brite and soapy water. Clean with degreaser, tack it off and paint. I've painted hundreds of these bumpers this way and never ever had one come back peeling.
Old Dec 13, 2014 | 12:07 PM
Hawkze_2.3's Avatar
You've "done hundreds", and that's where prep time comes into play. It sounds like you are painting bumpers professionally, so you need to get them done as fast and as cheap as possible without peeling. For a paint shop, there's no time to do restoration-quality prep.
If someone is restoring their own car or paying to have something done to high level of quality, then it would be important to do something better than Certi-fit primer. On my restoration, I primed and block sanded so that I would have an OEM or better finish that would last for many many years.
Mr2Rotor
Paint and Body
Apr 14, 2013 10:57 AM
yc_dc4mar
Oct 29, 2007 03:26 PM
hott-nix
Oct 7, 2005 10:23 AM
Andrea_Aunie
Jun 21, 2002 05:51 AM
Synthesis
Apr 25, 2002 01:17 AM
