93 Accord 5 speed will not turn over but everything else works fine
Old Aug 16, 2014 | 10:19 AM
horsepants's Avatar
Icon4 F22A6 dropped something in the head with the rocker cradle off... please help!!!???
I dropped a short metal peice with a magnant on the end, the adjustable ones.. down the left hole in the head of my F22A6 yesterday. right where the cradle for the rockers goes and all the valve springs are located, from the froht looking toward the windshield. anyone know how i could possibly get to it or where it could have fallen too? ive tried rare earth magnants on thin wire and can feel it but no clue where it is. Considering trying to pull the oil pan if it could have gone that far. any help would be greatly appreciated. That's all that is holding me up from running in less than an hour. thanks in advance... only could happen to me....
the rocker arm "cradle" is off right now but these few pics show what i mean.
Last edited by horsepants; Sep 20, 2015 at 12:37 PM. Reason: changing the whole thread... everything after the initial post is from a very old unrelated thread..
Old Aug 16, 2014 | 10:59 AM
tim73's Avatar
Default Re: 93 Accord 5 speed will not turn over but everything else works fine
By saying wouldnt crank, I assume you mean the starter wouldnt turn over at all? If this is the case, have to checked power at the starter when you turn key? Should have 12V at the big lug all the time, then when you turn the key, you should get 12v to the smaller solenoid lug(With the smaller wire) Any clicks?
Old Aug 16, 2014 | 11:08 AM
holmesnmanny's Avatar
Go to your nearest oreilly auto parts and ask for a "brake pedal stop pad".
Old Aug 17, 2014 | 07:45 AM
Lost Again's Avatar
Just me and my bad memory - and too lazy to look - but the lower switch is for the crusie control. The upper is the inhibitor for the starter circuit.
Old Aug 23, 2014 | 12:19 AM
Without looking at my car at the moment since its late it should just pop on. Ive actually never replaced one yet but i gotta think its pretty straightforward. Ill take a look tomorrow.
Old Aug 23, 2014 | 05:18 AM
Lost Again's Avatar
Get creative.
I've read where some have put a dab of glue/tape on the stopper and stuck it to a stick/screw driver and then used the "stick" to reach up in there and push it into the hole.
Old Aug 23, 2014 | 08:43 PM
Very easy to bypass. Unplug the connectors and stick a paperclip in them.
Old Aug 24, 2014 | 02:59 AM
Lost Again's Avatar
Just know if you do this the car will start in gear.
If you do the lower - that one should be easy to change - the cruise will NOT turn off when the clutch is pressed.
Old Oct 17, 2014 | 04:15 AM
horsepants's Avatar
again i just edited my first thread about my clutch but that's fixed all good. just need the door now...
steven253
Feb 11, 2026 01:48 PM
spaman
Sep 14, 2012 11:20 AM
Tim018
Jan 10, 2011 09:06 AM
sparknblaze
Dec 5, 2008 09:05 AM
dand39
Aug 13, 2007 04:47 PM
