Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2007 Civic EX automatic door lock issues
Old Aug 16, 2014 | 08:33 AM
EBP_Em1's Avatar
Default 2007 Civic EX automatic door lock issues
My girlfriend's car is having some issues with the automatic door locks. The keyless entry does not work - when you press the lock or unlock key, you can hear the car trying to unlock the doors but they don't unlock. We think this is because the driver side door cannot lock or unlock itself - it has to be done manually, either by key or, if inside the car, by flipping the lock switch on the door handle.
Because the car can't unlock the driver's side door with the keyless entry, none of the other doors will lock or unlock. I assume this is because the driver's side is the "master lock" on the car. If you lock the car from the outside with the key then use the keyless entry button to lock the car, the doors all lock fine. If you do not lock the driver door manually, then pressing the lock button on the keyless entry does not work - the locks sound like they're trying to lock but don't. Again, presumably these aren't working because the driver's door isn't locking, right?
When driving the car, once you hit 10mph the car tries to lock itself but, again, the driver door won't lock so none of the other doors lock. Then any time you slow down and go back over 10-15mph the car tries to lock itself again. It does this repeatedly while driving in stop-and-go traffic until you manually lock the driver door yourself.
Do we need to replace the door actuator? What would cause it to audibly attempt to lock but fail?
Old Aug 16, 2014 | 08:45 AM
DaveSi677's Avatar
Default Re: 2007 Civic EX automatic door lock issues
Sounds like an actuator... they are pretty inexpensive and easy to change too
Old Aug 16, 2014 | 08:55 AM
EBP_Em1's Avatar
Just called the local stealership and they quoted me $97 for the part. He mentioned something about the actuator being part of the door latch. That doesn't seem right, does it? I thought the part was like $30. Anyone got a part number or a link to where I can order it online?
Old Aug 16, 2014 | 10:05 AM
97emsedan's Avatar
The actuator is a solenoid that works on the latch assembly and is contained within it. Majestic Honda has them for $42.96 USD. Your dealership is trying to make a good buck off you.
Old Sep 21, 2015 | 04:56 PM
NeelanG's Avatar
Hi there,
I'm having the exact same problem.
How did you get yours fixed?
danmej1
Audio / Security / Video
Mar 20, 2010 11:17 AM
awwsnap
Honda Civic (2001 - 2005)
Feb 3, 2010 10:47 PM
brian2903
Nov 19, 2006 06:00 PM
rtcpenguin
10
Aug 3, 2006 07:39 PM
HondaVtec139
Jul 7, 2002 12:05 PM
