h22a7 obd2b engine harness into CD5 accord
Hi all,
currently doing h22a7 euro r motor into cd5 accord.
i have the cur running, but i couldnt 100% work out the engine harness wiring which go to underdash... which control the cluster etc.
can someone help me with this. i have tried to find the information around and have found about half, and still cant find the other half.
below is the pic of the connectors. engine harness is OBD2B... EDM
green connector
Gray connector
this is what iv got
Gray connector
1 yellow/black relay ground
2 black/yellow cmp power
3 white blue rpm
4 N/A
5 black/yellow cmp power
6 white/blue rpm
7 black/white coils ground -> i jumped this to black/yellow.
8 green fan control
9 black/yellow cmp power
10 black/white starter
Green connector
1 yellow back up light switch
2 brown black ?
3 yellow green coolant temp gauge
4 green black ?
5 blue white low fuel light
6 green black ?
7 green trunk ajar light ? NA
8 yellow red oil press light
not sure why some cables have the same color ? eg white/blue. black/yellow.
please correct me if any of above are wrong
any help will be appreciated.
thank you
green connector
Gray connector
this is what iv got
Gray connector
3 white blue rpm
4 N/A
6 white/blue rpm
8 green fan control
Green connector
2 brown black ?
4 green black ?
6 green black ?
thank you
I may have the wiring pinout on my desktop somewhere if that helps. Where do I have to post pics to host them? (New member).
Also was that grey clip usdm or JDM?
its jdm, you could just email it to me, wijaya.deddy@hotmail.com then i will host it here so people can see and get the information too.
thanks man
thanks man
