water coming out of exhaust
so my 95 accord is shooting out alot of water out the exhaust i did a compression test, and all four cylinders are at 128 to 130 psi and no loss of pressure at all so i dont think its a cracked block, theres no oil in the water or water in the oil, im trying to figure out where its coming from if anyone can help thanks
H2o (water) is a byproduct of gasoline combustion engine. http://www.autoshop101.com/forms/h55.pdf
There will be quite a bit of water from condensation buildup, especially if you have the factory muffler/exhaust system and the car has not been started in some time.
A decent 20min drive should clear out the moisture. As HonBeer mentioned it is a byproduct of combustion. If you are ever behind a newer car watch the exhaust, it will be drooling water at a long enough stop light.
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
dlenoxx
Dec 2, 2010 12:05 PM
please explain how his AC is connected to his exhaust? do you have any concept of how the AC works?
