2001 Civic Backfires & Shuts Off
Old Aug 12, 2014 | 03:27 AM
racerguy's Avatar
Default 2001 Civic Backfires & Shuts Off
I have somewhat of a problem. I have an 01 Civic with the D17 that I run dirt track with. I blew a head gasket a couple weeks ago and had a guy install a new one. Now just shy of 4000 RPM the car will backfire and shut off. No check engine light. I can stop, restart the car and it runs fine again until 3500-4000 rpm in which case it will happen again. The car has an aftermarket cam, ADJUSTABLE cam gear and is equipped with hondata. I took it to my hondata dyno guy and I don't know whether he didn't try or honestly couldn't find the problem but that was unsuccessful. Just looking for some opinions before I go throwing parts at it. Thanks in advance!
Old Aug 12, 2014 | 04:50 AM
Muckman's Avatar
Moderator in Chief
Default Re: 2001 Civic Backfires & Shuts Off
Its sounds like its a problem with the tune. We can only guess without having the actual calibration to look at.
Old Aug 12, 2014 | 02:02 PM
racerguy's Avatar
Well it all happened after a head gasket change. Would mechanical timing cause this problem?
Old Aug 12, 2014 | 02:17 PM
Muckman's Avatar
Moderator in Chief
Yes it could if timing was set incorrectly. Visually inspect the alignment marks or do a compression test.
hondcar86
Oct 16, 2015 01:30 AM
sohcmasta
Mar 18, 2005 10:53 PM
BoostedH23a1
Nov 7, 2004 10:31 AM
spooledex
Dec 30, 2003 09:45 AM
