Radiator fan timer switch?
Old Aug 10, 2014 | 05:11 PM
asoRm's Avatar
Default Radiator fan timer switch?
If this thing goes bad, can it stop the radiator fans from working???
The fuse is good, the relay is good, BOTH fans don't work. The switches I can't think both are bad. I connected 1 of the fans directly to the battery and it worked.
Old Aug 10, 2014 | 05:21 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Radiator fan timer switch?
What year Accord are you talking about?
Old Aug 11, 2014 | 06:15 AM
asoRm's Avatar
Woops, it's a 1997 Accord LX
I bought a radiator fan switch which I will replace 1 of the 2 with to test that.
Old Aug 11, 2014 | 06:40 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1. If the A/C system is functional properly, when you turn on the A/C; both radiator fan and A/C condenser fan should run at the same time.
2. Disconnect the Engine Coolant Temp. (ECT) fan switch A (located on the thermostat housing near the back of the engine) and jump the connector with a wire or small paper clip. With the ignition ON, both fans should run at the same time. The ECT Switch A, if functioning properly should also turn on both fans if the engine coolant temperature at the switch is about 199 degrees F or above with the engine running.
If both fans runs by jumping the fan switch A, the radiator fan control module (located behind the glove box) is probably good, along with the relays and fuses.
3. The driver's side fan is considered the A/C condenser fan and has the electrical connector up top. Since that is easily accessible, you probably tested that one already.
The radiator fan (passenger side) connector is at the bottom of the car. You may want to test that by using direct power and ground if the radiator fan doesn't move; but, the condenser fan does move, with the fan switch jumper test.
Old Aug 11, 2014 | 05:45 PM
asoRm's Avatar
I tried the Switch connectors with the wire trick.. Did not work either!! I am going to replace the timer switch by the glove box. If that doesn't work I am going to give up and make some switches in my car directly to the fans... This car was hacked to crap! I wouldn't be surprised that there is a wiring issue hidden somewhere.
Old Aug 12, 2014 | 04:54 AM
asoRm's Avatar
Woops, cancel that - I didn't have the Car on HAHA, was just accessories on. I will try today! SMH!
Old Aug 12, 2014 | 06:17 AM
asoRm's Avatar
Ok, just tested it again - still no dice. Going to replace the Timer Switch under the dash. If that doesnt work then it is certainly a wiring issue and ill bypass that crap. I cant believe how poorly this car was cared for!
Old Aug 13, 2014 | 06:45 AM
Padillaz's Avatar
I had the same issues with my 94 LX. First made sure my fuses and relay were good, then I took the connector off one of the switches (first one connected to the top radiator hose, I think it's switch B.) And shorted it with a paper clip and my fan didn't come on. Directly applied battery power to the fan and it didn't turn on... 20 minutes plus the 15minutes to auto zone, replaced the fan and the two switches (A and B) now my car runs cooler and the fan comes on by itself if the engine is too hot after I've had it on for a while.
Old Aug 13, 2014 | 12:10 PM
asoRm's Avatar
i dropped her off at a garage near me to get it going. I cant figure this cars electrical issues out.
crxguy406
Oct 26, 2023 09:24 AM
chellerfl
Jul 13, 2016 07:43 AM
herngonz
Jan 2, 2014 09:26 PM
thisdamnhonda
21
Feb 26, 2012 09:47 AM
808MAUI
Feb 23, 2006 07:51 PM
