PSI of the fuel pressure regulator
Old Aug 9, 2014 | 06:37 PM
gabrielsousa's Avatar
Default PSI of the fuel pressure regulator
anyone know the stock PSI of the fuel pressure regulator of the B16a1 and B16a2 ?
Old Aug 9, 2014 | 07:06 PM
br8crumb's Avatar
Default Re: PSI of the fuel pressure regulator
google is ur best friend
Old Aug 10, 2014 | 06:34 AM
i did that but didnt found a good answer
Old Aug 10, 2014 | 07:50 AM
F22Master's Avatar
36-37PSI for and OBD-0 B16
Old Aug 10, 2014 | 07:52 AM
thanks a lot :D
and for obd1 b16a2 do you know ?
Old Aug 10, 2014 | 09:35 AM
jlicrx's Avatar
pressure for OBD1 is same as for OBD0 - 35-38 with the vacuum hose at the fuel pressure regulator connected - also check it with the engine idling and the vacuum hose disconnected - with hose disconnected it should be 41-47
Old Aug 10, 2014 | 11:05 AM
I think isnt the same.
I havê a CRX b16a1 and i upgrade my pw0 obd0 to obd1 using p30 basemap I had to increase 20% of the fuel to get a 14.0 AFR . I'm using obd0 FPR
Old Aug 13, 2014 | 07:59 AM
found this...
dont know if is right
obd0
bar: 2,4 - 2,79 ||| psi: 34 - 40
bar: 1,75 - 2,14 ||| psi: 25 - 31
obd1
bar: 2,8 - 3,3 ||| psi: 40 - 47
bar: 2,15 - 2,65 ||| psi: 31 - 38
Old Aug 15, 2014 | 10:37 PM
~sp33~'s Avatar
EFB055
from the workshop manual, an OBD-0 B16 should have 35-41 PSI at idle with the vacuum line to the pressure regulator disconnected.
Old Aug 18, 2014 | 05:32 AM
zrickety's Avatar
38 worked good for me.
4ghatch
Apr 25, 2007 12:11 PM
hotimportcrx
Feb 4, 2005 08:31 PM
EFSiR
Dec 25, 2004 10:31 AM
quicksol95
Oct 11, 2004 05:51 PM
Wicked_CRX
Jul 11, 2003 06:30 PM
