1998 honda civic blower motor stopped working
Old Aug 9, 2014 | 05:04 PM
pityocamptes's Avatar
Default 1998 honda civic blower motor stopped working
I'm not sure where to start. None of the selections work but I notice that the ac button light is still lite. Where to start? Thanks.
Old Aug 9, 2014 | 05:23 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: 1998 honda civic blower motor stopped working
they normally get power from the ignition circuit, one of the key positions, and they switch ground through the switch for the different speeds, there are resistors in the blower housing for each speed, the moving air stops them from burning up. have you checked to see if the blower motor itself is any good? normally the fan will run on high, which is straight power and ground, but one of the speeds will fail , if it does nothing, check for power at the blower motor, and check to see if it's getting ground with the switch on. if it is, you might have to pull the blower housing and check the motor, edit it says 98 I thought it said 88, most likely it's the same setup honda has used for years, but I cant remember if they ever added a blower motor relay
Old Aug 9, 2014 | 09:03 PM
Thanks. Replaced the resistor and motor after doing some tests. Works great now. The motor was the issue, seems the brushes disintegrated so changed the resistor while I was in there...
mkfrl
Nov 14, 2018 04:45 PM
namingwaysway
Jun 18, 2014 05:25 AM
yh8me901
Dec 13, 2008 06:56 PM
bodiez
May 13, 2008 07:27 PM
riceboyEFsi
Jan 25, 2004 03:20 PM
