abs light and brake light
I have a 93 accord amd.the abs lights.always on and when I push my brakes sometimes my battery light flashes .. and its been recntly turning off the abs light and clock seem to dim and then.bright up again idk whats the problem anyone ?
Check the battery connections (both ends of both cables). Then have your charging system tested.
Not sure if the 4th gens are like the 5th gens but a "weak" charging system can and will trip the ABS light.
Is it the "brake lamp" or the "brake" light that is on?
Brake lamp - car icon, back of the car. Well there are a few things it could be. Bad bulb is the first place to start.
Brake - like if you have the e-brake on. Check the fluid level in the brake master cyl first. If low, you need to figure out "why". Brakes worn or a leak.
You replaced the end(s) at the battery - did you check the "other" ends of the cables?
There is a "service" connector on the pass side of the car. If you jump that connector (use a paper clip or piece of wire to join the two together) and then turn the car to on/pos II, if there are any codes stored in the abs system it will flash the code.
HONDA_TYPE_R
Nov 30, 2004 01:04 PM
