b18c 95mm crankschaft
Old Aug 9, 2014 | 01:13 PM
georgi's Avatar
Default b18c 95mm crankschaft
i have b18c botom manley h beams stock 89mm crankshaft and overbore size pistons 81,5 12;5,1 compresion, my question is can i replase crankshaft to 95mm and stil keep my manley h beam? thnx
Old Aug 9, 2014 | 03:21 PM
UncleD's Avatar
Default Re: b18c 95mm crankschaft
No.
Old Aug 9, 2014 | 03:25 PM
jimmysxxl's Avatar
Deck Plate and new Sleeves or Custom Pistons or Both..Or just go and buy a set of Rods if you got the Crank already.
Old Aug 9, 2014 | 04:25 PM
bigG's Avatar
Yes just buy stroker pistons most use regular length rods
Old Aug 10, 2014 | 02:08 AM
georgi's Avatar
i have crank already yes. that's why i thought i need different length rods. i wil keep my sleevs stock and keep same pistons.
clean rice: no? why not have you any experience with 95 crannk? just saying no will not help.
Thanks for information everyone,
Old Aug 10, 2014 | 07:25 AM
Chugger's Avatar
You can use the Manley rods with the 95 crank but will need pistons with raised pins.
You can use b16 length rods and use your pistons. I wouldn't advise it.
Old Aug 10, 2014 | 08:38 AM
UncleD's Avatar
It would be cheaper to replace the rods than do a custom piston.
You wanna spend more money - go ahead. Doesn't bother me any.
Old Aug 10, 2014 | 09:49 AM
PyroProblem's Avatar
Custom stroke = Custom Rods and/or pistons.
Old Aug 13, 2014 | 04:43 AM
4piston's Avatar
Its faster and cheaper to do the custom piston. A custom steel rod can take 6-10 weeks right now, and they are normally higher end rods close to $1000 or more. You can have them expedited for a few hundred more. The piston should take 3-5 weeks and will be less expensive.
Ideally if money were no object, you'd get a nice custom piston with the raised pin AND a nice custom rod
Old Aug 13, 2014 | 08:34 AM
Chugger's Avatar
I'm running a longer than stock rod in my 95mm setup a 5.531 rod to be exact. My pin height is pretty high.
Old Aug 15, 2014 | 12:27 PM
hondaracing84's Avatar
Id go the custom piston route. If you do custom rods, youd be getting shorter rods and that will make an even less than ideal rod ratio than the 89mm. Longer rods the better.
Custom pistons would be easier and cause less stress on the rods and skirts of the pistons.
Old Aug 15, 2014 | 03:30 PM
Same rod length I'm putting with a 92mm crank
Chugger,
With your wristpin and oil rings where they are, Is your oil consumption higher than normal or is it acceptable? Kinda curious what to expect whenever I finish my build...
OP- Whats your budget and we all can probably give you a decent bottom end parts list.
Old Aug 15, 2014 | 10:31 PM
UncleD's Avatar
I was thinking of Crower's rods they sell with the 95 stroker kit. Do they not sell them anymore? Used to be able to get them for $350'ish
Agnom
Mar 20, 2007 11:38 AM
StylishDOHC
Mar 23, 2006 09:42 AM
x2gold
Jun 1, 2003 04:08 PM
Acura_I-RS
Jan 2, 2003 08:40 PM
