Exhaust Manifold Removal?
Old Aug 8, 2014 | 02:47 PM
journeyquest's Avatar
Default Exhaust Manifold Removal?
Im doing the head gasket on my 90 CRX DX and have everything off except timing belt and exhaust pipe. Question: Is it better to disconnect at the front of the cat or downpipe in order to pull the manifold away from the head? Also what to do with the belt to keep it in place when i take it off the cam pulley? Want to try and finish getting this apart tonight. Thanks
Old Aug 8, 2014 | 03:15 PM
Freemananana's Avatar
Default Re: Exhaust Manifold Removal?
Cat. Then you pull it forward and it falls right off.
It will just stay there if you have a timing belt cover.
Old Aug 10, 2014 | 11:22 PM
~sp33~'s Avatar
EFB055
It's a good idea to mark a tooth on the belt, and then the teeth on the cam gear either side of the marked belt tooth so you know the belt is going on in the same position as it was taken off.
Obviously still double check your timing marks line up though.
ferio252
Nov 2, 2008 09:50 AM
NoVALude
Jul 19, 2006 11:53 AM
JDMlyfestyle
Nov 24, 2004 04:48 PM
MackDad
Oct 29, 2004 08:15 PM
jacques
Jun 27, 2001 04:01 PM
