Del sol loss of acceleration
Old Aug 7, 2014 | 06:05 PM
bman2700's Avatar
Default Del sol loss of acceleration
Recently bought a 93 del sol Automatic that the previous owner had sitting. I got it for very cheap and am more than impressed with the deal. It has 150xxx miles and the engine runs very smoothly. Here is for the bad part. Whenever you stop or slow down then give it a ton of gas it sits and sputters. It takes a good 5-10 seconds before you get the power you need. Only things that have been done to the car is added coolant and did a oil change. Also cleaned the IACV and throttle body thinking it had something to do with the problem. It didnt fix anything. I currently am starting to believe more that the problem is more due to a transmission sensor or something. Any help will be appreciated.
Thank you.
Old Aug 7, 2014 | 06:37 PM
Former User's Avatar
Default Re: Del sol loss of acceleration
Do a full ignition system tune up and replace the fuel filter.
Any CEL codes?
Old Aug 8, 2014 | 02:12 AM
andoxviii's Avatar
Yeah I totally agree with Ron here. The worst thing to do to a car is make it sit for any extended period of time.
Replace:
- fuel filter
- spark plugs
- ignition wires
- distributor cap
- distributor rotor
Inspect/clean:
- air filter
How long was the car sitting for?
Are you using the gas that the car sat with?
Old Aug 8, 2014 | 02:28 AM
shotoutacc0rd's Avatar
maybe the head gasket is bad
Old Aug 10, 2014 | 11:09 AM
bman2700's Avatar
It will toss a code under hard acceleration for EGR. In the middle of doing a full tune up now.
White_EG1
18
Aug 12, 2014 07:15 AM
del solares
Jan 12, 2013 06:46 PM
Deeppurple93
Jun 8, 2012 05:32 PM
TallgeeseIV
Jul 7, 2010 12:32 PM
l337jdmride
Dec 24, 2009 06:51 PM
