Ride a block, shuts off
Old Aug 6, 2014 | 10:07 PM
jonyi27's Avatar
Default Ride a block, shuts off
03 cbr 600rr
Bike has been sitting for 2 years but after charging the battery it will start but if I drive it a little, then stop at a stop sign it turns off, what I was thinking might be regulator, but the mechanic said it was good, any thoughts?
Old Aug 7, 2014 | 08:28 AM
MSchu's Avatar
My Name is Nobody
Default Re: Ride a block, shuts off
what did the mechanic say?
Old Aug 7, 2014 | 09:40 AM
veks's Avatar
Any gas in the tank when it was parked 2 yrs. ago?
Old Aug 7, 2014 | 10:03 AM
MSchu's Avatar
My Name is Nobody
clocked injectors...
Old Aug 7, 2014 | 10:06 AM
jonyi27's Avatar
Wouldn't it have trouble starting?
Cause it does but than give it a jump and it's good
Old Aug 7, 2014 | 10:16 AM
MSchu's Avatar
My Name is Nobody
yes, it would have trouble starting... but not turning over.
if you have issues turning over, it could be your starter... if it's trouble charging, it is your stator. you could also have a fuel pump issue or a clogged breather tube in the fuel tank.
Old Aug 7, 2014 | 06:53 PM
slomofo's Avatar
GDD Member
Your question is really vague. When you say it dies, are you referring to the BATTERY?
I know the engine dies with it, but since you say regulator and you also mentioned charging the battery, I'm wondering if you're talking about the voltage regulator.
Old Aug 7, 2014 | 06:59 PM
kelsodeez's Avatar
derp resistant
yea sounds like a failing stator (basically the motorcycle equivalent to an alternator). it dies because the revolution of the engine is recharging the battery and the EFI isnt getting any power to push fuel through the injectors. i had this happen to me on my old gsxr.
but to diagnose, i think we need more info. your description of whats going on is vague at best OP
Sinche
Honda Motorcycles
Jun 22, 2006 08:55 AM
p nut
Honda Motorcycles
11
May 31, 2006 01:14 PM
green98civic
Honda Motorcycles
Oct 1, 2004 06:28 PM
Surreal
Sep 28, 2004 06:10 PM
b16_incarnate
Oct 5, 2002 10:23 PM
