01 F4i Starting trouble
Hi guys,
Im in need of some help. 2 weeks ago i went to start my vehicle and when i removed my button from the starter the bike completely died. first thoughts were maybe the battery is completely drained. Im in Tx and it does get hot here, plus i havent gotten a new battery since the vehicle was bought in '01. I tried recharging the battery but its not charging. I got it jumped and it still has the same problem. Whenever i release the starter button it just dies. It does start up but like i said when i release my finger away it just dies......
A little history, prior to this happening to me.. on several different occassions I would be riding and coming to a stop from a high speed like 55 to 70 mph, and the bike would just die out. i had to press the starter and give a little throttle to keep it up.
Please anyone have any thoughts what the problem could be?
Re: 01 F4i Starting trouble (Sinche)
if your battery were dead it wouldn't start at all. Although the fact that the battery isn't charging is a bad sign, still, it doesn't make sense that it would turn over and then die.
It's possible that you're not getting spark or something.
Re: (marmaladeboy)
Ok, check the sparks and the RR... mind telling me what RR stands for? Yes its a honda..
thanks for the responses..
Exactly a good point about the battery being completely dead... if it was dead it wouldnt start in the first place...
Re: (Sinche)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinche »</TD></TR><TR><TD CLASS="quote">Ok, check the sparks and the RR... mind telling me what RR stands for? Yes its a honda..
Exactly a good point about the battery being completely dead... if it was dead it wouldnt start in the first place...</TD></TR></TABLE>
If the battery was dead it wouldnt even crank. To me, sounds like a spark problem if as soon as you let off the starter it dies.
RR = Regulator/Rectifier
My CBR exhibited similar symptoms to what you were describing when my RR started to crap out. Once it's gone, your battery is next.
Re: (marmaladeboy)
Sounds somewhat like the problem I was having. I bet a new battery will solve it for the moment, but maybe look into a new rectifier like lmaomadeboy said.
Re: (Mr. PengUIN)
Thanks for the quick responses guys, i appreciate it alot.
So maybe i should check my sparks?
Marmaladeboy, did you get any problems after replacing your RR?
thanks for the help.
incognito E46
05-30-2005 05:06 PM
