Spoon Cams k20 k24
Spoon all motor cams
K20/k24
Brand new
1200 Obo shipped + 3% Paypal unless gifted. Got plenty of vouches.
Introducing the infamous Spoon Racing Camshafts! The ultimate road race cam, Spoon cams are developed to produce greater mid to high RPM range power without sacrificing low rpm torque. Spoon cams are manufactured and machined by Honda according to Spoon specifications. Spoon cams must be tuned with adjustable cam sprockets to obtain maximum power gains. Valve clearance is suggested (IN 0.18mm +/-0.02) (EX 0.22mm +/- 0.02). Spoon cams even come with a spec sheet showing the measurments of each individual cam lobe!
Whenever performance camshafts are installed, we recommend the use of stiffer high-performance valve springs to eliminate the chance of valve float. Factory valve springs cam handle up to 8,300rpm, while the use of aftermarket springs can handle revs in excess of 9,000rpm. For Type-R owners, we recommend to at least add titanium retainers to your existing factory setup.
K20/k24
Brand new
