d16y8 to d16z6 ! please help me my Honda people.
so i have a 98 Honda civic ex, and my engine blew last week. since its my daily driver i went and bought a cheap working d16z6 swap with 147 miles on it. I've done my research and i know my car is obd2a and the z6 is obd1. if im not mistaking i'll need a obd2a to obd1 jumper harness and a obd1 ecu witch most likely will be a p28. can i just drop the full swap in and use the harness and the p28 ecu and call it a day ? im really new too this and some forms confuse me and say you could use your ob2 ecu ? i just want too drop the full swap in the car and not have too use parts from the y8. please help you guys. i'll appreciate it.
You'll have to swap over your alternator and injectors for plug and play. Also the distributor won't plug and play and the Z6 distributor won't plug and play either. The Y8 distributor will barely bolt up as well.
Kevokay123
10
Aug 11, 2014 03:53 PM
nightscream
11
Oct 28, 2010 04:02 PM
bunnyx
Apr 30, 2008 01:53 AM
