Square peg round hole? H22 CRX
Hi all,
I got my engine back from a tuner builder who failed to complete the build. Anyhow he wanted to run a standalone ecu that used a coil pack and trigger wheel with hall sensor. So he did away with the distributor and put a blanking plate there. Now i've got it back i'm going to go down the chipped p28 route and so need to add the distributor. Here is a pic of the problem ....
On another h22 motor I have its got the notch for the distributor. So im thinking this isn't a h22 cam he's put in or has he put the inlet one on the exhaust. Would that matter? If not i'll check the other one and swap them over.
Thanks for any help guys n gals
