Vx harness question
Old Aug 6, 2014 | 01:21 AM
EG_BOI6's Avatar
Default Vx harness question
I have a 95 vx hatchback civic with a b20 non vtec. The harness was custom made and works but I came across a vx oem harness was gonna keep it to take off the engine light cuz of the o2 sensor but I read HONDATA can disable it so is it worth keeping cuz I paid like 200 on eBay or just get an ex harness
Old Aug 6, 2014 | 02:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Vx harness question
WTF are you saying?
Old Aug 6, 2014 | 08:49 PM
EG_BOI6's Avatar
In a nut shell do I need to use a vx harness with my vx civic or can I use any other vtec harness
Old Aug 7, 2014 | 01:40 AM
The Grumpiest
What's wrong with it now?
Old Aug 7, 2014 | 08:37 AM
EG_BOI6's Avatar
Well I bought a swap and I need a engine harness but I heard I need a vx harness cuz of the 5 wire o2 sensor. so I'm asking do I absolutely need a vx harness or can I use an ex harness
I have a 95 civic vx hatch
Old Aug 7, 2014 | 08:43 AM
The Grumpiest
You are not answering the question. Is there any problems with the harness you are using now? I could care less about what you heard.
Old Aug 7, 2014 | 03:19 PM
n/a2boost's Avatar
The vx is the only harness to use a 5 wire o2. Most Hondas use a 4 wire o2. So if not using the vx motor or ecu you need to either mod the vx harness to use a 4 wire o2 or mod the ex harness.
Old Aug 7, 2014 | 03:37 PM
The Grumpiest
Or use the MODIFIED harness that you say is working okay.
Old Aug 9, 2014 | 12:10 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
It seems like he's saying that he's wondering if he needs a new harness due to a CEL for the O2 sensor light he's getting. He has a VX car, but he doesn't have a D15Z1 motor, he has a B20 in it! So a different harness isn't going to solve anything, but diagnosing the CEL and fixing that will. OP needs to invest in a service manual.
Old Aug 10, 2014 | 03:19 AM
94EG8's Avatar
Seagull Management
Old Aug 11, 2014 | 09:03 AM
EG_BOI6's Avatar
I just bought a vx harness and connected the o2 and it cleared
Old Aug 11, 2014 | 10:03 PM
raverx3m's Avatar
theres a lot more difference to vx harness than that . just make sure you check everything
google vx 4 wire conversion and check to see if the dash harness and ecu plugs are correct. I cant remember but theres something else different I think ground distribution is not same on vx harness
Old Aug 13, 2014 | 03:49 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
As 94 eg posted. You are just repinning the wire at the shock tower . Also, there is one more to rep in for vtec to work. The Vx chassis harness makes it super easy for vtec swaps
EG_BOI6
Aug 18, 2014 03:46 PM
RStoR
Jan 19, 2010 12:54 PM
kajay1972
Sep 7, 2007 09:15 PM
R_type
Feb 11, 2006 09:33 PM
92hybridAccord
May 6, 2004 12:00 PM
