98 Civic EX Locks Question
Old Aug 5, 2014 | 05:26 AM
thedangsallhere's Avatar
Default 98 Civic EX Locks Question
Hi,
I have a 98 Civic EX sedan with some lock issues. When I press the power lock switch on the driver door I can hear the actuators moving but nothing happens on any of the doors except the rear passenger.
The rear passenger lock only unlocks with the power switch, no matter if I press lock or unlock - it will unlock and not relock itself.
The driver side lock is stiff and I cannot lock it manually at all. If I use the key from the outside it doesn't stay locked and slides back up when I pull the key out. It doesn't lock when I hold the handle open either.
From what I understand in other threads it could be either the driver door actuator or the lock control module. Can someone please point me in the right direction?
Old Aug 5, 2014 | 08:08 AM
JDM_SOHC's Avatar
Default Re: 98 Civic EX Locks Question
You answered your own question
Old Aug 6, 2014 | 06:11 AM
Haha so.....replace both?
Old Aug 6, 2014 | 07:33 AM
Former User's Avatar
Sounds like bad lock actuators, but make sure it's not a mechanical lock problem before replacing.
Old Aug 6, 2014 | 11:35 AM
Thanks I will do that. So if it were the actuators I would have to replace them on all the doors? I read somewhere that the driver door kind of controls the rest of them? Not quite clear on that part.
ajcarrico@gmail
24
Mar 27, 2017 07:20 PM
dynamatt
Honda CR-V & Element
Jul 20, 2016 11:38 AM
Qvart
Honda Civic (2001 - 2005)
Mar 26, 2015 12:10 AM
gripwig
Jun 21, 2008 10:58 AM
EF8IGHT
Apr 14, 2006 09:25 PM
