pullys
Old Oct 31, 2002 | 12:05 PM
3g6's Avatar
3g6
Default pullys
can someone tell me how exactly a pully gives you more hp gains? got diagrams so i get the picture better?
Old Oct 31, 2002 | 12:24 PM
4g4me's Avatar
Default Re: pullys (3g6)
No picture or diagrams needed. When you order performance under drive pulleys they do exactly what they say.........underdrive the accessories. The larger the accessory pulley, the slower it spins, reducing drag on your rotating assembly. The aftermarket pulley will be lighter, and larger, both reducing drag and rotating mass, this is a know physics control that will provide a slight, sometimes unnoticable power increase. I am not trying to talk you out of them, because a couple small power adders equals one large power adder.
Old Oct 31, 2002 | 02:54 PM
96 SOHC VTEC's Avatar
Default Re: pullys (4g4me)
Yeah, a total waste of $$$$. .1hp at the flywheel. Hold on tight! Not to mention your headlights always dim when you are at a stoplight, and if you have a sub you most likely will be going through a boat load of batteries.
Old Oct 31, 2002 | 03:23 PM
LB CRX's Avatar
Default Re: pullys (96 SOHC VTEC)
dont forget to mention how they f*ck up the balancing on the crank. not worth it unless you have a race car IMO
Old Nov 2, 2002 | 07:25 PM
3g6's Avatar
3g6
Default Re: pullys (LB CRX)
well now i know.... coo thanx guys and/or gals
K24.20A
Sep 24, 2007 06:52 PM
AccordSleeperZzZ
Sep 20, 2006 01:41 PM
thomas188
Jul 1, 2006 03:21 PM
user 931176363637
Oct 18, 2005 02:32 PM
AWR19
Jul 28, 2003 03:05 PM
