Oil leak 1993 Honda Accord ex
Old Aug 3, 2014 | 12:39 PM
pain999's Avatar
Icon2 Oil leak 1993 Honda Accord ex
Leak seems to be coming from the valve cover gasket if i replaced it would it fix it? http://imgur.com/aMSrVMH
Old Aug 3, 2014 | 02:08 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Oil leak 1993 Honda Accord ex
Looks like the grommets have a bit of oil in them.
Best thing to do would be to use some simple green/409 and then hose off all the areas where there is wet/weeping/puddling. With no visible oil leakage, start the engine and watch for any active leaks. If none, go for a drive, preferably in hilly areas where the car will be pitched and rolled a bit. Park car and look for any new oil leaks. If you see wet spots, that is most likely your oil leak. But if a sloppy oil change was done it may just be spilled oil from the container, and your engine may not have any active leaks.
Old Aug 3, 2014 | 02:42 PM
jmanuel's Avatar
Yes looks like a simple valve cover fix.( new grommets should come with new gasket kit) if fixed and leak still persist make sure you placed it on correctly and tightened all bolts the right torque specs. And you could always spray some carb cleaner around suspected (with car off) area to clean off and see if any oil leaks out.
Old Aug 3, 2014 | 02:43 PM
94 accord typeR's Avatar
looks like u need new grommets. if it continues to leak replace
http://www.carparts.com/results/?N=0...90&universal=0
kind of expensive u might want to get a valve cover gasket kit and replace the tube seals as well. when u install them use soapy water on the grommets and wipe clean after install
Old Aug 3, 2014 | 02:44 PM
jmanuel's Avatar
Should do what mad mike suggest tho just incase
Old Aug 4, 2014 | 10:56 AM
pain999's Avatar
I washed all the oil of the motor today and the problem was the grommets so i changed them and now i car wont come on i think it has to do something with washing the oil off
Old Aug 4, 2014 | 12:12 PM
pain999's Avatar
thanks for all the help got the car started again , and there is no oil leaking it was the grommets
Old Aug 4, 2014 | 05:29 PM
MAD_MIKE's Avatar
MM Gruppe B
Pull out your spark plug wires, you may have flooded the spark plug tubes with water. Just need to spray off, using just the hose without an attachment could flood the engine or worse.
HndaOwner
May 10, 2014 04:24 PM
curtie94
Jul 9, 2011 09:16 PM
SuperChic[k]
Jan 21, 2008 09:14 PM
vietkangta
Sep 21, 2006 09:21 PM
ajth87
Jun 29, 2006 12:59 PM
