t bracket issue
Old Aug 3, 2014 | 12:09 AM
eghatch07's Avatar
Default t bracket issue
I have a 94 hatch with b16 swap. It has a b16 cable trans. I can only seem to get the top T bracket bolt to line up. I guess my question is, is there a difference in the span of the bolt holes from a hydro to a cable trans. Also, is there a difference in the span of the bolt holes in the different B series T brackets. Thanks!
Old Aug 3, 2014 | 03:20 AM
94EG8's Avatar
Seagull Management
Default Re: t bracket issue
Yes. From what I remember you need a '90 - '93 Integra 5 speed T-bracket.
No, other than hydro and cable are different. The legnths of the T-brackets themselves are different depending on what they came out of though. '99 - '00 Si T-bracket is shorter than one for an Integra or '92 - '95 Civic.
You'll also need an aftermarket or custom upper transmission mount. Honestly it's a lot better to just find a hydro transmission and sell what you have to an EF or DA guy.
Old Aug 4, 2014 | 03:48 AM
eghatch07's Avatar
I already have the swap mounts. I have a custom made trans mount from innovative. Just wondering which T bracket I needed for the bolt holes to match.
revikan
Sep 2, 2010 04:27 PM
00b18b
Jun 5, 2008 09:37 PM
B18CUL8R
Mar 3, 2007 07:08 PM
gldndrgn14
Mar 28, 2005 08:43 AM
STG3PWR
Feb 19, 2005 08:27 PM
