RTV sealant on water pump ?
Old Oct 31, 2002 | 11:52 AM
raene's Avatar
Default RTV sealant on water pump ?
Do I need to RTV-seal a Honda OEM water pump O-ring? It seems to be flush-mounted to the waterpump somehow, don't want to pry it off... do I still need to seal?
Old Oct 31, 2002 | 11:59 AM
tonyxcom's Avatar
Default Re: RTV sealant on water pump ? (raene)
you dont need to seal it, you need to replace it.
Old Oct 31, 2002 | 12:19 PM
raene's Avatar
Default Re: RTV sealant on water pump ? (tonyxcom)
I know I know, the new waterpump comes with the new O-ring embedded flush against it. I'm asking if I need to run a bead of sealant around that also.
When I said o-ring, I meant on the new pump
[Modified by raene, 1:20 PM 10/31/2002]
Old Oct 31, 2002 | 01:45 PM
tonyxcom's Avatar
No, you dont need any other sealant. the oring is all the gasket that you need. just make sure to clean the mating surface on your blcok and you should be fine.
Old Oct 31, 2002 | 02:10 PM
raene's Avatar
Excellent, thank you sir
Champs32
Feb 14, 2009 07:28 PM
ZXRider
Aug 13, 2007 06:08 PM
Blk-dc2
Sep 26, 2006 01:06 PM
B18PoweredCivic
Jul 25, 2003 01:37 PM
highmilehatch
May 25, 2003 04:22 AM
