'10 Odyssey Brake Caliper Piston Reset
Old Aug 2, 2014 | 05:25 AM
mtacket45's Avatar
Icon6 '10 Odyssey Brake Caliper Piston Reset
Does anyone know if there is any truth to a rumor I heard that with newer cars (such as my van), in order to reset the piston of the brake caliper, you must now compress the piston with the bleeder valve open? I heard that it was bad for the system to push that fluid back up through the lines, just taking the master cylinder top off...any ideas about this?
Old Aug 2, 2014 | 11:04 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: '10 Odyssey Brake Caliper Piston Reset
It is always best to bleed out any fluid from the caliper. This is the fluid that will most likely be contaminated, overheated, or generally just lost its properties. When pushing the pistons back in, open the bleeder and remove the old caliper fluid. Once the fluid is clean/clear of impurities, close bleeder, install new pads, reinstall caliper. Check fluid level in MC and move on to the next caliper.
Old Aug 3, 2014 | 01:18 AM
holmesnmanny's Avatar
Or you can push the fluid back in, and after doing both brakes do a brake flush/bleed.
MotorMouth93
Apr 12, 2015 01:54 PM
St3v3
Jan 2, 2008 04:52 PM
eudm_eg8
Jun 19, 2006 11:23 PM
deviant1
Jun 26, 2003 08:42 PM
