Re-skinning the roof on my CRX, anyone have experience with this?
Old Aug 1, 2014 | 03:00 PM
IDriveHonda's Avatar
Default Re-skinning the roof on my CRX, anyone have experience with this?
I posted a thread about this in the CRX/Civic 88-91 Forum but though that it might get more views here.
Here is my original post:
https://honda-tech.com/forums/showth...9#post49873789
If anyone can offer me any tips or advice I would appreciate it. I have read a few good write ups on it but it is definitely harder than it looks. Thanks.
Old Aug 1, 2014 | 03:10 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Re-skinning the roof on my CRX, anyone have experience with this?
some people use the 3m panel adhesive now, stuff is made for bonding panels and wont warp the metal, they use it for roof panels on some new cars, not sure how structural the roof is to the overall car, I know the reinforcing under it is, but not sure about the actual roof skin
Old Aug 3, 2014 | 09:32 PM
Hidenplanvew's Avatar
You should still spot weld the panels, even door skins usually have a couple spots welded in the window channel.
Old Aug 4, 2014 | 11:19 AM
I am having problems separating the panels after the welds are drilled out, the sections in the rain rails are tough to get to.
Old Aug 5, 2014 | 08:00 PM
look on autobody tool mart, they have a seam separator or something like that. But if you have a steady hand use a grinder and slowly grind it down. make sure you don't go to far into the base metal.
Old Aug 5, 2014 | 09:31 PM
gorillafart's Avatar
just make sure you have removed all the spot welds. drill all of them out. and separate with that hammer and chisel. there shouldnt be anything else holding it down other than welds.
after you've separated the front and rear, then you can attack the sides
Old Aug 18, 2014 | 01:48 PM
I just wanted to give an update, I found a few more spot welds on the bottom side of the panel that were not visible from the top and drilled those out but also had to cut through some seam sealer or type of adhesive with a knife before it came apart easily. Thanks for the advice. Next step is to take the windshield out and start on my actual car, its a little scary but I should be able to do it. Wish me luck.
VtecSyndrome
Nov 23, 2010 03:01 PM
mrtrex
Mar 9, 2006 12:29 PM
girliehonda
Dec 28, 2005 01:57 PM
redline94
May 20, 2004 10:05 AM
Eggman
Aug 21, 2002 02:48 PM
