94 hatchback - Fuse #15 keeps blowing every time I put it in reverse
Old Jul 28, 2014 | 08:48 PM
Rios209's Avatar
Default 94 hatchback - Fuse #15 keeps blowing every time I put it in reverse
I have a problem
I already check the wiring that goes to the reverse lights and everything seems good
Need help ??
Old Jul 28, 2014 | 08:58 PM
andoxviii's Avatar
Default Re: Honda 1994 hatchback
We don't all have EG civic fuse diagrams. Why don't you tell us which fuse that is?
Old Jul 28, 2014 | 09:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Fuse 15, 10 amp fuse - Clock, Gauge Assembly, Hazard Switch, Back-Up Lights, Interlock System, Integrated Control Unit.
Hope that helps you isolate your problem.
Old Jul 29, 2014 | 03:36 AM
Former User's Avatar
Default Re: 94 hatchback - Fuse #15 keeps blowing every time I put it in reverse
Auto or manual transmission?
Inspect the reverse lights bulb sockets.
Old Jul 29, 2014 | 05:42 AM
Rios209's Avatar
Manual transmission
I check the lightbulb sockets they seem fine
Old Jul 29, 2014 | 05:55 AM
angrysmileyface's Avatar
When you checked them, did you use a multimeter or just pull the bulbs out and eyeball for corosion?
Old Jul 29, 2014 | 09:14 AM
Rios209's Avatar
Tests with a multimeter no power
Also every time I do put it on reverse the alternator kicks in like it draws a lot of amps through it
Old Jul 29, 2014 | 09:41 AM
tony_2018's Avatar
Fish Twig
Someone must've tapped into the circuit for other reasons and probably goofed on it. You're gonna have to go through that circuit to locate the wiring.
Old Jul 29, 2014 | 10:07 AM
Rios209's Avatar
I had diz car for 3 years now and it berly started doing it
I disconnected at the connection dat goes to the wire harness and test the wire for the reverse lights no power
Does anyone have a wire diagram ??
Old Jul 29, 2014 | 03:28 PM
Test ground also. If you have both power and ground, then the bulb is bad.
Old Jul 29, 2014 | 03:58 PM
tony_2018's Avatar
Fish Twig
What did you disconnect?
Old Jul 29, 2014 | 03:59 PM
NotARaCist's Avatar
I never narc'd on nobody!
Alternatively, there could be a damaged wire that is grounding out. That would also explain why your alternator is freaking out - a damaged, grounded wire reverse light wire making solid contact with the frame would be just dumping power into it.
Old Jul 29, 2014 | 04:03 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
have you checked at the reverse light switch itself? is this a manual or auto?
Old Jul 29, 2014 | 04:05 PM
didn't see the manual part, disconnect the wires at the switch, one wire should go all the way to the lights, disconnect it and see if it's grounding out, Honda is different in that they switch voltage to the reverse lights instead of a ground switch, the fact that it only does it in reverse is indicating that the short is past the reverse switch
Slabre
Sep 28, 2009 03:08 PM
sleeperrex
Aug 24, 2008 04:12 PM
queda
May 23, 2008 08:42 AM
ludesrv
Jun 26, 2007 08:03 AM
KCDelSol
Feb 28, 2003 08:55 AM
