94 hatchback - Fuse #15 keeps blowing every time I put it in reverse
I have a problem
I already check the wiring that goes to the reverse lights and everything seems good
Need help ??
Need help ??
Re: Honda 1994 hatchback
Fuse 15, 10 amp fuse - Clock, Gauge Assembly, Hazard Switch, Back-Up Lights, Interlock System, Integrated Control Unit.
Hope that helps you isolate your problem.
Re: 94 hatchback - Fuse #15 keeps blowing every time I put it in reverse
When you checked them, did you use a multimeter or just pull the bulbs out and eyeball for corosion?
Tests with a multimeter no power
Also every time I do put it on reverse the alternator kicks in like it draws a lot of amps through it
Fish Twig
Someone must've tapped into the circuit for other reasons and probably goofed on it. You're gonna have to go through that circuit to locate the wiring.
I had diz car for 3 years now and it berly started doing it
I disconnected at the connection dat goes to the wire harness and test the wire for the reverse lights no power
Does anyone have a wire diagram ??
I never narc'd on nobody!
Alternatively, there could be a damaged wire that is grounding out. That would also explain why your alternator is freaking out - a damaged, grounded wire reverse light wire making solid contact with the frame would be just dumping power into it.
longest project ever
Location: on the south side of dixie, 1986 Accord Hatch
have you checked at the reverse light switch itself? is this a manual or auto?
didn't see the manual part, disconnect the wires at the switch, one wire should go all the way to the lights, disconnect it and see if it's grounding out, Honda is different in that they switch voltage to the reverse lights instead of a ground switch, the fact that it only does it in reverse is indicating that the short is past the reverse switch
Slabre
09-28-2009 03:08 PM
KCDelSol
02-28-2003 08:55 AM
