Help~axles
Old Oct 31, 2002 | 10:40 AM
IamVtec's Avatar
Default Help~axles
i checked all the axles and cv boots, and they are fine. the right one was recently replaced 4 months ago. But when i make a LEFT turn the right one clicks (until the turn is complete) or sometimes make a thump noise. Can anyone tell me whats wrong with it? Thanks
Old Oct 31, 2002 | 11:42 AM
nsxmatt's Avatar
Default Re: Help~axles (crx dragga)
Axle may not be seated right or it just went bad again.
Old Oct 31, 2002 | 11:46 AM
joey1320's Avatar
Default Re: Help~axles (nsxmatt)
i'm having the same issue with mines... check if its leaking the grease on the boot.
u might have to replace it, sorry...
i think i'll have to also, my boot is leaking grease
(i hate having to replace axles... suspensions are a bitch to deal with)
Old Oct 31, 2002 | 12:55 PM
IamVtec's Avatar
Default Re: Help~axles (joey1320)
the boot is fine, i dont see any leakage comin from it
Old Oct 31, 2002 | 01:01 PM
kshymkiw's Avatar
how about clearance with brakes and what not? My friend had this in his ITR when he had rims on his car. I would checl your clearances and make sure everything is fine
Old Oct 31, 2002 | 01:21 PM
nsxmatt's Avatar
Did this problem start after you put the HF tranny in??
Old Oct 31, 2002 | 01:33 PM
IamVtec's Avatar
Had the HF tranny in b4 i had to replace the axle , say if it was an Si axles it wouldnt fit from the git go right? so that probably wouldnt be the problem
[Modified by crx dragga, 5:34 PM 10/31/2002]
raffydogg
Dec 18, 2008 09:45 AM
Joe-G
Feb 5, 2008 10:55 PM
poorman's type-r
Dec 3, 2005 03:45 PM
leadfoot78
May 26, 2003 12:17 PM
myNAteq
Oct 21, 2001 07:44 PM
