smog check failed
i took my car in to get a smog and while they were doing the smog my heater hose busted so it overheated, but i fixed the hose, but i got the report back and it failed the low rpm test, but passed the high rpm test. on the list of test it passed all but the "ignition timing: TDC" and it says it "failed the ignition timing check due to engine rpm being out of tolerance" it runs fine doesnt seem like the timings off but any help would be appreciated thanks
95 accord lx 2.2 4cyl A/T
Your idle rpm is out of spec, either too high or too low. Also honda's timing is not tdc it is either 12,15,16, or 18 btdc. Sounds like you took it to a rookie.....
yeah it was idling at over 1000 i just adjusted it now its 650 700, i dont have my timing light, but i tried turning my distributor and anywhere i turn it, it either laggs if i turn it clockwise at all and if i turn it ccw it gets kinda jumps every like 5 secs or so (im guessing a miss due to advancing the dist.) so i dont think the distributor needs to be turned so hopefully itll pass now that the idles adjusted
thanks alot
thanks alot
and now they wont retest my car until i do a diagnosis and see whats wrong, they just want money cos they wont tell me anything not even what caused water to get everywhere, "they didnt know" so im wondering if i should just take it somewhere else
Ok you gotta stick a paperclip into the blue service connector located in the passenger side floor dash area to adjust the timing or you be fighting the ecu.
When you jump the service connector the check engine light will turn on solid which is normal.
ok will do that thanks, im sure you saw the pic of my report, it also says high co%
i got new plugs but not wires, the car doesnt lag at all when i advance the timing but when its on time is when it lags but once it gets to like 10 15 it picks up fine
Im curious if you valve lash is set correctly. If the timing is correct then the car should be what I would think would be optimal.
You are running rich, probably 13:1 with the lack of ODeuce.
CO2 should be in the 15% ideally.
If your idle is still hunting check your FITV and IAC as per the FAQ at the top of the page.
Check your plug gap, if it is too big it will also cause some slight hunting/vibration at idle.
Lack of O2 is causing a lack of O2/CO2 and increase of CO, since there is no O2 too combine with.
When you fix the problem, the other emissions may increase, but will be at an acceptable level.
If your NOx goes through the roof, you may need to clean the EGR manifold that is bolted to the intake manifold, under the fuel rail.
cleaned my IACV
and I havent checked the gap in my plugs since i didnt put em in i can see the person putting it in thinking its ok cos their "pre gapped"
and i also cleaned my EGR too
remove the negative battery cable for 20 sec. it will reset the ECU now that ur timing is correct and will have a blank basemap to record ur acceration and driving habits with
i did that as well, it only accelerates normal when i advance the distributor, but like i said then its out of time
check the ohms on ur wires. u will need a multimeter. new wires should be 1.xx-2.xx some wires wont even give u a reading (broken inside) general rule is under 25,000 ohms is acceptable
or maybe its the FITV
but if the wires were bad would it still respond better when advanced wouldnt it still lag?
