FS: GSR long block
Old Jul 28, 2014 | 02:05 AM
93geezr's Avatar
Default FS: GSR long block
Block:
NPR Pistons, PR-3 81.5 (about 11:1 comp ratio)
ACL Rod and Main bearings
OEM seals and gaskets
OEM Rod studs and nuts
Assembled at RS Machines
Head:
Edelbrock cams
Supertech Dual springs and retainers
ITR Copy IM
Blox 68mm TB
Aftermarket Cam seal
Rep-SMSP Tri-y Header
Thermal Intake Gasket
Extended IM Studs
OEM seals
Will not come with dizzy, injectors, PS Pump, flywheel, and clutch.
So there's a small issue with the motor that needs addressing. I recently did a leak down
test to confirm there's a leak in the head. It's coming from cylinder #1 intake side.
Possibly a valve seal issue. However, all other cylinders tested fine (about the 15% range).
Motor has about less then 10k on it.
Looking to get $1200 obo CASH.
(818) 266-1824
Old Jul 28, 2014 | 11:28 AM
93geezr's Avatar
Default Re: FS: GSR long block
Any takers?
Old Jul 28, 2014 | 10:59 PM
kingofbattle909's Avatar
ttt
Old Aug 31, 2014 | 03:42 PM
Maluko's Avatar
Playa sunday bump
Old Sep 24, 2014 | 09:43 PM
DoHc714's Avatar
leak is kinda a deal breaker but post what is the psi its holding up at
just to show how minor or major it is
give it a better chance for sell
bump for honesty!
lets get this sold!
Old Oct 6, 2014 | 09:22 PM
JayDeeEm420's Avatar
what years the motor?
Old Oct 8, 2014 | 07:43 AM
ttt
Old Oct 8, 2014 | 05:01 PM
93geezr's Avatar
bump for honesty!
lets get this sold!
Cylinder one was at 65% (35% loss). It's a pretty bad leak, so I kind of gave up on selling the motor. I'm in the process of pulling off the head for a rebuild/PnP.
1994
Originally Posted by kingofbattle909
ttt
tttt
xshytlipsx
May 10, 2011 10:41 AM
98GSR-Turbo
Nov 22, 2010 10:50 AM
Toda Party
Mid-Atlantic (Sales)
Jun 2, 2010 03:30 PM
Toda Party
Jun 2, 2010 10:15 AM
Toda Party
Northeast (Sales)
May 31, 2010 12:39 AM
