00 civic keyless entry problem (solved)
Hi guys
I just brought a 2000 Civic. I love it except the keyless entry won't work. I've been told by the seller it is because the battery on the transmitter. I changed the battery on it and it still won't work.
1. when i press any button on the remote, red light on the remote flashes but no response from the car side.
2. power lock on the driver door works perfectly: lock and unlock all four doors.
3. I tried to reprogram the keyless by on and off the ignition four time and press lock every time it 's on. I am sure i did it correctly but still no respond.
4. It came with the stock radio. radio works fine.
5. I checked the kick panel, the receiver is there!
6. One more thing, the car came with a security system handbook. Both the model for the transmitter and radio are different from the car.
The transmitter I have doesn't have a option button and the radio I have doesn't have a valet switch.The handbook refers to a transmitter with option button and radio with a valet switch.Is there anything to do with the nothing working keyless ?
7. please help !!! any thoughts ?
What Civic trim?
The transmitter is correct for a 99-00 Civic.
Have you checked fuses 51, 30, and 14?
There are also control unit input tests that can be done with a multimeter.
1. the Vin# contains EJ6, i'll say it is a DX
2.fuse 30 and 14 check out. don't know where to find fuse 51. can't find it in the manual
3. I don't have a multimeter and I don't even know how to use it. but I did disconnect the unit and make sure it is properly connected.
EJ6 ---> it's an LX
Under the hood
You'll find nifty fuse box diagrams in the FAQs sticky.
If the problem is not as simple as a blown fuse, then you need multimeter -- less than $10 at Harbor Freight Tools
2.fuse 30 and 14 check out. don't know why to find fuse 51. can't find it in the manual
So I guess I have to get a multimeter tomorrow then. seems like it's my best shot
Thank you
Or pick one up for free at Harbor Freight, NO PURCHASE NECESSARY!
http://www.dealsoff.com/harbor-freight-coupons/
Enjoy.
eH.
re2417
16
Jun 7, 2012 04:43 PM
CIVIC dude
11
May 10, 2005 10:52 AM
