p/s delete
Old Jul 25, 2014 | 03:47 AM
Tepe's Avatar
Default p/s delete
First off this isnt for hp or room for a turbo. This is to get my car running asap and cheap.
I have a 94 honda accord 2dr
My rack broke so im replacing it. And as you can guess my rusty lines wont come off. 1 is already broke. I planned to cut them and eliminate power steering. What is the cheapest eay to keep the rack lubricated.
Old Jul 25, 2014 | 05:15 AM
NerfGunner420's Avatar
Default Re: p/s delete
THROW SOME POWER STEERING FLUID DOWN THE LINES WHILE THE POWER STEERING LINES ARE FACING THE SKY ONCE THEY ARE FILLED SOME PCV PIPPING BETWEEN BOTH HOSES SHOULD DO DOES FOR ME..
Old Jul 25, 2014 | 07:00 AM
hondamark35's Avatar
replacing all of the fluid with grease and sealing the rack is the cheapest and a good long term solution, but it's very involved and I wouldn't recommend it in your situation.
the two smaller lines feeding the rack cylinder are the ones you want to loop together. after cutting (I used a hack saw) them and smoothing the sharp edges, top them up with fluid and loop them together with some hose (I used fuel hose which should last a long time and stand up to the fluid and other stuff in the engine bay.) the fittings on the valve body can be plugged. work from the lowest up and add some fluid before capping the highest port.
there are other ways of doing this with fittings and so on, but fittings cost money. I had all of the stuff laying around (caps, hose, fluid and hose clamps) but if I had gone out and bought all of that:
clamps - $2.5
hose - $2
fluid - $3
caps - $2.5
total - $10
keeping plenty of air in the front tires will help reduce the turning effort
Old Jul 25, 2014 | 09:55 AM
1native's Avatar
I got the fitting off another car .and filled the rack with fluid . Then I looped the lines .so it would circulate when turning .
'06-V6-MT
Jun 30, 2015 05:47 PM
Axatax
Sep 28, 2013 01:56 AM
dan_g
Dec 27, 2011 08:49 PM
Pilchard
Jul 9, 2004 07:17 PM
mattcalica
Jun 29, 2004 11:10 PM
