passenger side wheel
Hope someone can help me
I have a 94 honda accord everything was going good with the car until I lowered it. Ever sense I lowered it the back passenger tire looks to have positve camber and the rest have negative camber. I can't drive the car in the snow or even rain because that back tire is toed in and tries to turn the car to the left. I've had the car on a hoist and nothing looked bent and the wheel has no play in it and all bushings are good... someone please help
No I haven't gotten an alignment yet just bc there's nothing to really adjust in the back and I was going to do the camber kit but I kinda just wanted it right.... bc I had the same set up on mt last car and I had none of this problem
some cars allow u to adjust camber/caster on the suspension. even an alignment. it wont be as accurate as a laser alignment but it possible. ill check my FSM and see if it has instructions
"NOTE: Caster angle can be adjusted by increasing/decreasing the number of the adjusting shims. Remove and install the radius rod each time the caster angle is adjusted"
-CD7_CD9 FSM
front/rear toe-in can be adjusted with the self-locking nut etc.
dont u love 4 wheel independent suspension
-CD7_CD9 FSM
-CD7_CD9 FSM
-CD7_CD9 FSM
Caster isn't going to help the camber.
If the rear camber is off - there are kits you can get, adjustable rear upper sontrol arms....or get some longer high grade bolts (grade 8), a few shims and add those between the body and where the rear upper arm bolts to it.
Last, please try to help people by posting somthing close to correct info. I understand you are learning things but don't assume anything without understanding the system and knowing how to repair said system.
Have you ever adjusted rear camber on a 5th gen? I have.
here is the manual.
50MB, 1400 pages.
https://mega.co.nz/#!t1Vn0CzJ!6RYWjI...xi8920DjpaclNo
Good luck
50MB, 1400 pages.
Good luck
lxaccord51oxl
Feb 27, 2007 07:53 PM
