2000 civic, aftermarket radio won't turn on
Old Jul 24, 2014 | 11:50 AM
ej8_00's Avatar
Default 2000 civic, aftermarket radio won't turn on
So I started up my car this morning and the deck won't even turn on at all, I tried pulling it off and putting it on again and nothing at all.
Also checked the fuse under the wheel and seems to be fine, i even changed it and still nothing.
Anyone got any clue what this could be?
Thanks
Old Jul 24, 2014 | 12:14 PM
OptimisticWay's Avatar
Default Re: 2000 civic, aftermarket radio won't turn on
Who installed it and what method did they use to install it?
Maybe the power wire disconnected behind the head.
Does the head unit itself have an internal fuse?
Can you remove the head and supply power to it?
Old Jul 24, 2014 | 12:24 PM
ej8_00's Avatar
I bought the car with the aftermarket deck in it. It's been working since i bought it 3 months ago.
Last night I took off the negative cable to work on my spark plugs....and everythings working fine.
I just noticed the radio wouldn't even turn on so I guess I gotta open it apart and check everything.
I haven't worked on decks before so I wouldn't be able to tell you but I'll take it apart now and check everything
thanks
Old Jul 24, 2014 | 01:35 PM
Does anything else not work currently?
Fuse #23 15amp is for the Radio. Is this the one you inspected? Do you have an digital multimeter?
Old Jul 24, 2014 | 01:38 PM
If you don't have a digital multimeter (DMM) pick one up if there is a Harbor Freight near you for free. NO PURCHASE NECESSARY.
http://www.dealsoff.com/harbor-freight-coupons/
Old Jul 24, 2014 | 01:57 PM
ej8_00's Avatar
Wow it works fine now....I guess there just a mulfunction?
That's weird. But yeah thanks again man ill pick up one of those multimeters
Old Jul 24, 2014 | 02:08 PM
grumblemarc's Avatar
The Grumpiest
I wouldn't count on it not doing that again.
Trey Boston
Audio / Security / Video
Mar 27, 2019 10:38 AM
Salvi-EJ1
Jun 28, 2014 11:07 AM
BojeEM2
Mar 29, 2011 07:24 PM
iJDMBB6
Mar 17, 2009 05:58 AM
Gman8941
Sep 26, 2004 05:17 PM
