2005 Civic - P1457
Im having trouble with the P1457 code on my car. I had the EVAP 2-way valve replaced by Firestone but now they are saying the second valve is no good.
How many valves are connected to the P1457 code?
I believe there are three on the canister and one sensor at throttle body these are pruge solenoids. I have replace the whole think it started with two of valves at the canister but then it was still giving problems so I replace the whole thing meaning the whole canister along with valves etc. from honda dealer. Hope this help.
Hey guys,
I have a Honda Civic 2001.
Its giving me the P1457 code.
I have to pass an emissions test this month.
1. Can I unplug the battery (or remove the right fuse) to turn off the Engine light and then replug the battery wires, drive to the test, and pass it that same day???
2. Does removing the battery power reset the code P1457 ?
3. If my Engine light turns off does that mean the computer wont issue a P1457 error code when hooked up to the emission system?
-Mandy
-Mandy
this is an Evaporative Emission code so you will not notice any driveability issues or and change in gas mileage. it just means if the system isnt working correctly (reason a code is set) you could be allowing more fuel vapors (unburned hydrocarbons ie smog )to vent/escape from fuel tank system than normal.
Hey guys,
-Mandy
-Mandy
Hey guys,
-Mandy
-Mandy
2. Yes it does but the code will eventually reappear.
3. No it won't issue a P1457 error code when hooked up to the emissions system, but it still will not pass emissions due to your engine monitors not being ready.
mjones123
Honda Civic (2006 - 2015)
Nov 7, 2017 05:52 AM
