manual vtec Engagement ?
if the former, yes. you will just need to look up the pin-out of the VTEC ECU you're using to find out where the wire needs to hook in.
If the later, like grumblemarc pointed out it's not a Saturday morning cartoon "turbo-thrusters GO!" the solenoid is just an electro-mechanical device that activates the hydraulic half of an electronically controlled system. without the ECU doing its half of the work at VTEC engagement you're really just switching cams on the fly and running a bad tune. it may make more noise, but it won't be doing much more.
Ryan Arnold
May 7, 2016 05:54 PM
Einhander276
Aug 2, 2011 05:47 PM
vtecn8ive
Apr 20, 2006 09:14 PM
