93 integra brake/suspenion converion on 89 civic si hatchback
Old Jul 22, 2014 | 05:48 PM
kenneth4g4d's Avatar
Default 93 integra brake/suspenion converion on 89 civic si hatchback
So ive read a few threads on doing a break upgrade from the 89 si civic disc front with drum back to the full disk from a 93 integra.
So a bit of info on the car first. It a 89 civic hatchback si, i have a 92 integra as a back up car, and a 93 integra i bought 7 years ago which is now my full donor car. The civic recieved the motor/tranny/shift linkage/axles/radiator/ecu and a few other misc pieces. The runs great so far but the brakes just arent the same as driving a DA integra for 7 years after owning an EF sedan lol.
So from what ive read is mostly about the rear brakes, and they are just unbolt/bolt on for the most part with no fabrication at all it seems. My question now is should i go ahead and do the fronts aswell or is it not really worth the work since it has disc already? Or should i since it was be nice to have the same setup from front to rear, since the integra brake system requires a min 14" tire (a 13" wont clear it) and the 89 si hatch min needs a 13"?
I would ask on the big thread i read but it was hijacked by so many people and seems half didnt really know what they were talking about (half said 1 thing half argued) so im starting my own to see what info i get.
Thanks
Old Jul 22, 2014 | 07:02 PM
F22Master's Avatar
Default Re: 93 integra brake/suspenion converion on 89 civic si hatchback
The front civic is 9.5" disk, teg is 10.3. It's a very popular upgrade. If you really want to step up the front brakes, you can get ITR calipers and 11.1" mini cooper rotors (which is what I am doing!)
Also, I personally think the rear disks do not add much braking performance. There is so little weight in the rear, the drums can easily hold their own.
Old Jul 22, 2014 | 07:20 PM
hmm if thats the case then no point changing i dont think the lil extra in the front would be much better but i could be wrong. you dont think the disc in the rear would do much?
But if i was going to goahead with doing the conversion to full DA brakes it looks farily simple and bolts up.
what about the suspension the front could use a lil stiffer with the b18 in it and the rear arent in best condition and since i have the donor why not lol
Old Jul 23, 2014 | 02:58 AM
F22Master's Avatar
The front brakes are worth doing. It is a noticeable increase in braking capacity.
Old Jul 23, 2014 | 10:09 AM
Ok then I'll just do all for since i got time and the parts
Old Jul 23, 2014 | 10:29 AM
Freemananana's Avatar
Just a question, do you need the ITR caliper and mini rotor or the entire ITR knuckle? I'm on DA (10.3" rotor) knuckles at the moment. It's definitely a different feel than the stock (whatever standard hatch) brakes.
Old Jul 23, 2014 | 11:38 AM
F22Master's Avatar
Just the itr caliper and mini rotor. They both bolt right up to the da or ex knuckles!
Old Jul 23, 2014 | 01:02 PM
Oh jesus. Now I have to do this!
Old Jul 23, 2014 | 05:32 PM
hmm i would go that route but with a donor DA sitting with fairly new rotors/pads just cant pass it up lollemme how it turns out Freemananana
Old Jul 24, 2014 | 04:05 AM
F22 will finish it long before I even start. I have new rotors and pads on my DA knuckles too.
young-gun92eg
Suspension & Brakes
Mar 17, 2013 05:47 AM
zoomsbestcusty
Feb 21, 2006 09:34 PM
Black_eh2
Aug 5, 2003 11:25 PM
brian.edge
14
Dec 6, 2001 06:26 AM
