AC Clutch Won't Engage (2000 civic dx)
Old Jul 22, 2014 | 03:51 PM
alarainredondo's Avatar
Default AC Clutch Won't Engage (2000 civic dx)
AC clutch will not engage. Got it to engage and blow cold air when I put a paper clip in A17 and grounded it to a bolt in the foot well. Also when I jumped the compressor relay (85 to 30) and grounded 87 to the negative terminal of the battery. Any ideas on where the problem is?
Old Jul 22, 2014 | 04:45 PM
Former User's Avatar
Default Re: AC Clutch Won't Engage (2000 civic dx)
Does the condenser fan run?
Old Jul 22, 2014 | 04:48 PM
Yes
Old Jul 22, 2014 | 04:49 PM
If you unplug the pressure switch and ground the Blu/Red wire in the connector, does the clutch engage?
Do you have a multimeter?
Old Jul 22, 2014 | 05:08 PM
Clutch does not engage, but definite change in engine sound. Yes I have a multimeter.
Old Jul 22, 2014 | 05:09 PM
ECU is bad. Replace it.
Old Jul 22, 2014 | 05:23 PM
Any idea on what can cause it to go bad? Can I buy one on ebay and swap it and everything should work normally? Do you know if it is possible to replace a transistor within the ECU to get it working?
And just for my own knowledge, does the ECU trigger a ground to get it engaged?
Old Jul 22, 2014 | 05:26 PM
Not sure, but keep in mind it's 15 years old.
Yes and yes.
Some ECU fixes are possible. Open it up and look for any obvious damage.
Correct.
Old Jul 22, 2014 | 05:49 PM
Thanks so much for your help! After hours of research and troubleshooting I had narrowed it to the ECU, but with my very limited knowledge of this stuff I couldn't be sure.
I opened the ECU up and everything looked great, except for connector A had what felt like oil, but was a little green when I cleaned it off, all over it. Any ideas on how this can happen?
Old Jul 22, 2014 | 06:24 PM
...except for connector A had what felt like oil, but was a little green when I cleaned it off, all over it. Any ideas on how this can happen?
Some dielectric grease is applied to some connector mating surfaces to seal from moisture. Reapply fresh grease.
Old Jul 22, 2014 | 06:34 PM
andoxviii's Avatar
Wait, you said the engine noise changes...?
Wouldn't that mean that there is extra drag on that belt, and therefore the clutch IS engaging?
I'm definitely not an expert on A/C systems but... that's my 2 cents.
Old Jul 22, 2014 | 06:38 PM
Pushing the A/C button signals the ECU to ramp up the idle speed. I assumed the OP was hearing this. Perhaps he can clarify. He did clearly state that the clutch did not engage.
Old Jul 22, 2014 | 06:48 PM
Yeah the clutch did not engage when trying the pressure switch grounding test. When I disconnected the ground I noticed the noise change, reconnected and the noise changed again. I did not know that was idle speed...now I do! Thanks!
Old Aug 5, 2014 | 04:10 PM
I replaced the ECU with one on ebay, about $30, and everything works perfectly. Thanks for your help!
Old Aug 5, 2014 | 05:48 PM
Thesmitty
Jul 24, 2012 07:17 PM
cncgod
12
May 31, 2011 06:35 PM
Mackln308
Jul 30, 2010 11:34 AM
chulew
Aug 30, 2009 08:38 AM
bodean
Nov 5, 2006 05:44 AM
