Looked Everywhere - Proper Timing for D16Y7 Mini Me?
Old Jul 21, 2014 | 11:19 PM
nuclidex's Avatar
Default Looked Everywhere - Proper Timing for D16Y7 Mini Me?
Hey guys., What is the proper timing for a D16Y7 with a Mini Me swap?
I have the Y8 Head, Mani, TB, P2P ECU (pretty much everything mini me swapped)
The D16Y7 is said to run at 12 degrees, and the D16Y8 is said to run at 16 degrees. So with the higher compression that the D16Y7 has, what would be the optimum timing for the best fuel efficiency and all around smooth running?
Old Jul 22, 2014 | 02:03 AM
Bently_Coop's Avatar
Steve at Heart
Default Re: Looked Everywhere - Proper Timing for D16Y7 Mini Me?
Are you refering to timing as in timing belt or timing for ignition? Timing belt on the y7 and y8's are the same. Iginition timing see picture provided from the FAQ link above.
Ilovemyef9
Oct 21, 2010 04:41 PM
titosek4
Jul 25, 2009 04:58 PM
luvs2spooge
May 18, 2007 05:42 PM
ncskate
Jun 15, 2005 07:23 PM
