ok who would be interested in this security device
I am from michigan and there really are not that many theifs of imports around here but i just finished my swap and really paranoid about it getting stolen(way to much of my hard work).
I was talking to my dad who is a electrical engineer an we are making a device that uses a keypad and a 4-5 digit code to "lock" both your fuel pump and igniton, and then you can hide the keypad, and you can't steal a car without fuel!!
But anyway would anyone else be interested in this?
Pm me if so, cause you guys in socal seem to get your cars stolen daily and i know you guys could use something like this if we did make a kit it would come with everything to install it and a "how to" plus it would be easy just splice some wiring, because all the brains would be if the keypad box. btw i have a ton of references so this is not some scam. It would be like 50 bux shipped maybe less have not priced it out yet
To the moderator if I should not have posted this delete it, but I thought this i something everyone could use.
[Modified by twitchm80, 5:22 PM 10/31/2002]
no offense, but if its just a matter of splicing both of those lines and the keypad is the brain setup, all they have to do is find the brain and cut and tape the wires..... maybe make the keypad separate and relocate the brain, just a thought
if u do make the brain and keypad separate I would be interested.
First the key pad would be seperate from the "brain", you hide the brain somewhere that would NEVER be found, second then the keypad on your dash, so if a thief tears off the keypad and splices the wires back together nothing will happen because the brain will give the output based on keypad input so that would not work.
Second you spice into your fuel pump/ Ignition under the dash as well hiding it as well so really no thief could ever find it/ break in to it.
Third, come on guys this is just a CHEAP little device to add for some security, a good system is like 250 and more difficult to install,
and Finally This will work well since its not mainstream thiefs will not know what to do with it let alone find it because everyone can put it in a different place. makes it more custom, and much more difficult to compromise, because do you think a thief is going to take 30mins to find where you spliced you wires up under your dash, they will go elsewhere like someone with a huge clifford box under there dash
No offense but they will prob either just tow the car away if they really want it or steal what they can off of it. My friend was selling his car in front of his house and we got back from the bars and the car was goone with two big *** tire marks. Some one pulled up with a roll back and drug it up onto the roll back and away went his nice car. If they want it they will take it. The more **** you have on your car to make it harder for them to steal the less they will waste their time on your car unless you got something they really want. IMO.
with the device does it mean everytime i turn off my car.. i have to push the code in again? is there an arm and unarm feature or something?
asubennett
Dec 28, 2005 05:09 PM
