IDLE Surging no CEL, Unplug IACV, No Surge w/CEL.
Old Jul 20, 2014 | 02:27 PM
bignosewhipper's Avatar
Default IDLE Surging no CEL, Unplug IACV, No Surge w/CEL.
1991 Civic STD
Short Block - d15b1
A6 Head
p32 intake/TB
pm6
MONOTech Harness
So I did an MPFI swap recently and am now at the point of not getting any CEL codes when everything is hooked up. The problem I am having is the surging idle issue. RPM's from 1500 - 2000 and it keeps bouncing.
What I have done:
-cleared any air bubbles in coolant system, twice.
-checked all vacuum lines with carb cleaner, no leaks
-checked all intake bolts on intake manifold, all torqued and installed properly
-Replaced IACV (albiet with a used IACV but guaranteed)
Every time I plug the TOP air hole in the throttle body (IACV) the surging stops and the idle goes back to normal ~750 rpm and no issue. Power is awesome, and everything works well with no CEL.
This lead me to think it was the IACV so I bought one off of ebay and installed it. It didn't change a thing and the surging continues, however, when I plug the hole again, the car works as it should. I have taken the IACV out and cleaned it with carb cleaner, let it dry, and re-installed. I get the same Surging issue but no CEL.
Now, when I unplug the IACV from the harness, and start the car, it throws a CEL 14, which is what it should do, but the surging stops and the car works but with a little hesitation. When I plug the sensor back in, CEL goes away and the surging starts once again.
I know I'm close but can't for the life of me figure it out. I need some guidance.
Thanks in advance for your response.
Last edited by bignosewhipper; Jul 20, 2014 at 02:44 PM. Reason: model and specs of car
Old Aug 3, 2014 | 10:56 AM
Default Re: IDLE Surging no CEL, Unplug IACV, No Surge w/CEL.
Replaced IACV, surge still there, however it's a little softer than before.
Any ideas?
I have not re-learned the fuel relay yet, hoping thats it.
Old Feb 8, 2015 | 05:02 PM
vxhbb16a's Avatar
Originally Posted by bignosewhipper
1991 Civic STD
Short Block - d15b1
A6 Head
p32 intake/TB
pm6
MONOTech Harness
What I have done:
So what did you find out on this?
whyS0serious
22
Jun 28, 2013 05:56 PM
SergioE92
May 21, 2013 06:35 PM
dth0ng69
Nov 11, 2009 09:16 AM
.Radical_Edward.
Feb 9, 2006 05:23 AM
