Sounds like engine wants to stall out
Hi I'm having trouble figuring out whats wrong with my car.when I turn it on it sounds like it wants to stall out. Like if there's a choke on it. And it doesn't idle normal. Any one know whats wrong????
What he means is, you need to supply us with more information. Perhaps about the car? Any work done recently? Any check engine lights? Any information at all?
Yeah a check engine light went on but turned off. No other work. There is oil on my block and I have a pinched header but was told it wasnt that bad. Its a b20b motor with a gsr head swap.
You really have to do better with the information you're supplying. All we know right now is some weird idling issue on a B20V in some unknown car.
Right now? It could be anything. ECU (MAP). Timing. Tune-up. Anything.
