93 civic ex driver window
window will not roll up by itself, the driver nor passenger but when i hook the regulator up to a battery it works, i replaced all fuses and have tried multiple switches any suggestions thanks.
In the driver's door jamb, check that the black ground wire in that harness connector has not come loose, etc. You have to gently pull the rubber grommet off the harness connector to see the wiring.
Roxas13
Aug 12, 2012 04:10 PM
JDMEMone
Jun 28, 2012 08:37 PM
