Where do these engine harness plugs connect to?
Old Jul 19, 2014 | 04:38 PM
CrooksEK's Avatar
Default Where do these engine harness plugs connect to?
98 civic EK d16y8
I have 4 unused connectors on the wiring harness.
2 by the distributor
1 by the battery tray
2 by the head light/radiator
Old Jul 19, 2014 | 04:47 PM
CrooksEK's Avatar
Default Re: Where do these engine harness plugs connect to?
Also, car cranks but won't start up.
Old Jul 19, 2014 | 04:52 PM
grumblemarc's Avatar
The Grumpiest
Is it a harness from an automatic?
Old Jul 19, 2014 | 04:55 PM
CrooksEK's Avatar
I don't believe so.
Old Jul 19, 2014 | 05:03 PM
The Grumpiest
What do you mean you don't "Believe" so? It either is or it isn't.
And you might also want to mention that the car is boosted.
Old Jul 19, 2014 | 05:04 PM
The Grumpiest
Also, 2+1+2=5.
Old Jul 19, 2014 | 05:08 PM
tony_2018's Avatar
Fish Twig
What ecu are you running?
Old Jul 19, 2014 | 05:10 PM
The Grumpiest
Seriously. You want help? You better list everything done to that car.
Old Jul 20, 2014 | 04:36 AM
HondaPartsHero's Avatar
Technical Hero
Just gonna go by visual ID:
1st pic: 4 wire connector is oxygen sensor, could be either primary or secondary, post wire colors, 2 wire connector is reverse switch (post colors)
2nd pic: evap control canister vent shut valve (post wire colors)
3rd pic: either connector could be intake air temp sensor (post colors) and evap purge solenoid (post colors)
Old Jul 20, 2014 | 04:49 AM
The Grumpiest
^^^That's the method. Post the wire colors for each. I'll remember that for future since a couple of connectors can mistakenly be switched (to bad effect).
Old Jul 20, 2014 | 07:05 AM
OptimisticWay's Avatar
Awesome reply.
Old Jul 20, 2014 | 08:24 AM
tony_2018's Avatar
Fish Twig
You're boosting so what ecu do you have?
Old Jul 20, 2014 | 11:39 AM
CrooksEK's Avatar
video of the wires/trying to turn over
https://www.youtube.com/watch?v=jIoa...ature=youtu.be
zdiddy22
Oct 14, 2013 08:51 AM
tj051
21
Apr 16, 2012 08:09 AM
HarosGSRek
17
Mar 29, 2009 10:37 AM
arc_55
Welding / Fabrication
Mar 23, 2008 12:09 AM
turbo sol
May 23, 2003 06:21 PM
