H22 no tach
Old Jul 17, 2014 | 02:22 PM
Camhaas's Avatar
Default H22 no tach
Okay guys I've tried searching and searching but still nothing. I need my rpms to work (wire up) I have an h22a4 block with out a cps and a h22a head with JDM dizzy. And a p28 ecu. My problem is that I have a aftermarket tech and a stock 97 civic DX tach but both of them are not working and I've tried taping the wire harness before the ecu and the blue wire off the dizzy and still nothing. My tune is coming up in 11 days and need to get this figured out ASAP
Any help would be greatly appreciated. Thanks
Old Jul 17, 2014 | 03:40 PM
Camhaas's Avatar
Default Re: h22 swap rpm wire up
Bump
Old Jul 19, 2014 | 06:16 AM
Camhaas's Avatar
9 days till tune bump
Old Jul 21, 2014 | 07:00 AM
Camhaas's Avatar
7 days till tune please help
Old Jul 22, 2014 | 03:49 AM
holmesnmanny's Avatar
Call rywire and ask them for a distributor conversion adapter kit. They will either have one or make one.
Old Jul 22, 2014 | 05:19 AM
Muckman's Avatar
Moderator in Chief
The blue wire off the dist doest work? It should. make sure its the correct blue wire. Read the documentation for the aftermarket tach, it should give you some clues.
Old Jul 22, 2014 | 05:45 PM
Camhaas's Avatar
Default Re: H22 no tach
Just put in the cps and nothing. I'm tune is in 6 days and I have to figure this out
Old Jul 22, 2014 | 06:26 PM
Camhaas's Avatar
Its the TD60 dizzy if that helps
Old Jul 22, 2014 | 07:22 PM
n/a2boost's Avatar
The tach wire is the blue wire in the two wire plug of the distributor.
Old Jul 23, 2014 | 02:41 AM
HondaPartsHero's Avatar
Technical Hero
Worst case there should be a two wire connector on the drivers side with a blue wire for tach signal.
radicaled434
20
Jun 4, 2015 04:27 AM
Tyson
40
Jun 4, 2009 04:24 PM
esean93
Aug 23, 2008 10:33 AM
1sikhatch
11
Mar 14, 2006 09:19 PM
projectcrx
May 15, 2002 10:36 PM
