No fuel, No Spark, No start.
Old Jul 17, 2014 | 10:52 AM
FullOutPwr's Avatar
Default No fuel, No Spark, No start.
I've done some searching and am kind of stumped. This occurred after a compression test. I pulled 44 out before the test as many threads have said to do. So far, I've done the following:
Checked fused 13 and 44 at the test sites, both are good.
I hear one click from the main relay. I've tried swapping with a known good, new relay to no luck.
Distributor is getting 12v at the large black power supply wire.
No power at the fuel pump.
I've pulled a plug wire and using a plug tried grounding to the valve cover to check spark and nothing.
Edit- OBD1 conversion car. Ran OK before being parked and fuse 44 pulled and compression test done.
Old Jul 17, 2014 | 04:46 PM
FullOutPwr's Avatar
Default Re: No fuel, No Spark, No start.
Fixed! Thanks.
brucepick
32
Nov 21, 2009 05:47 AM
95teg_ls
Apr 21, 2008 08:42 AM
Bngo731
Jun 5, 2006 02:42 PM
xhimurakenshinx
Mar 29, 2005 08:12 PM
ownedbyvtec
Oct 4, 2003 09:56 PM
