How do I reset my srs light
Here are the steps that I use to reset the SRS light on my 2000 Honda Accord.
1. The plug is located below the dash on the drivers side. It is against the right side plugged into a panel. It does not have an electrical connection to that panel. I leave mine unplugged and hanging for easy access if I need to reset the SRS light again.
SRS light reset plug on a Honda Accord
2. You will need a paperclip, piece of wire or something that can easily be used to short out the plug. I use a paperclip. With the key off, connect the paperclip to both ends of the plug. I am connecting the circuit in a specific order to reset the SRS light.
3. Hold the wires together (short it) while you turn the ignition on (turn key to on position, not start). The SRS light will come on for a couple seconds and then go out.
4. When the SRS light goes off, disconnect (un-short) the wires.
5. The SRS light comes on again, connect the wires again.
6. The SRS light will then turn off. Disconnect the wires. The SRS light should blink twice and your SRS light and system will be reset.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
t-town_ep
Jul 25, 2007 05:11 AM
DumpedSi
Sep 11, 2003 08:42 PM
