94 accord LX. guess the nut size!
Old Jul 16, 2014 | 06:39 PM
wwolf771177's Avatar
Default 94 accord LX. guess the nut size!
Sway bar bushings nut. I saw a video tutorial and the kid used 12mm wrench and socket. I went to majestic honda and looked up the part number and it says 8mm.
so which is it 12mm or 8mm. Here is the part number 90362-SF1-003.
I also included a pic below. I left my car at my job if not I wouldn't be posting this question. I would have just checked. Thanks
Old Jul 16, 2014 | 06:55 PM
1991civiclx13's Avatar
Default Re: 94 accord LX. guess the nut size!
I beleive that 8mm refers to the bolt diameter not the head size
Old Jul 16, 2014 | 07:13 PM
accordturb96's Avatar
honda bolts are typically in even mm increments, I would say a 12
Old Jul 16, 2014 | 07:22 PM
holmesnmanny's Avatar
12mm
Old Jul 16, 2014 | 08:25 PM
Thanks guys.
Old Jul 16, 2014 | 10:28 PM
You will need something to hold one side while you turn the other as it will spin free if you try to just turn one side. Keep that in mind. You can just put a 12mm wrench on the top and then just use a socket on the bottom and the wrench will bottom out against something and you can just turn the bottom with a socket or you can hold the wrench if you want.
Old Jul 17, 2014 | 03:41 AM
Fitz Williams's Avatar
10 Year Member
If someone has replaced the nut with an aftermarket one, it could be 13mm. OEM is 12.
Old Jul 17, 2014 | 02:27 PM
Its pretty clear in the pic its oem. Moog would be 14mm.
Old Jul 17, 2014 | 02:32 PM
Lost Again's Avatar
Again, is the question about the thread size or the hex size?
Old Jul 17, 2014 | 02:43 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Originally Posted by wwolf771177
I saw a video tutorial and the kid used 12mm wrench and socket. ....
Old Jul 19, 2014 | 01:35 PM
v4lu3s's Avatar
RTFM
you use a 12mm wrench/socket on 8mm bolt/nut. the measurement is NOT the head size or outer size of the nut/bolt the measure is of the diameter of the bolt.
Old Jul 19, 2014 | 03:39 PM
danameisoj's Avatar
The book number is for thread pitch sizing. Not the actual head size
MarcusGallardo
Jul 22, 2017 04:28 PM
Johnisriot Accord
Sep 29, 2008 08:05 AM
pa_itr
Dec 10, 2007 12:15 PM
vtec95
Nov 29, 2006 10:07 AM
MulletManRockStar
Sep 3, 2004 10:46 PM
